Adabas Universal Connector Implementation Guide for Guardium Data Protection
Table of Contents​
  1. Overview
  2. Architecture
  3. Prerequisites
  4. Implementation Steps
  5. Configuration Reference
  6. Troubleshooting
  7. Appendix
Overview​
This guide provides step-by-step instructions for implementing the Adabas Universal Connector with IBM Guardium Data Protection. The Adabas connector enables Guardium to monitor and audit Adabas database activity without requiring traditional S-TAP agents.
What is the Universal Connector?​
The Guardium Universal Connector is a framework that allows Guardium to receive and process audit data from various data sources through their native audit logs. It uses a Logstash-based pipeline with three components:
  1. Input Plugin - Receives audit data from the data source
  2. Filter Plugin - Parses and transforms the data into Guardium format
  3. Output Plugin - Sends processed data to Guardium (internal component)
Adabas-Specific Architecture​
The Adabas implementation uses a custom input plugin that connects directly to the Adabas Auditing Server via EntireX Broker, rather than using standard log forwarding methods like Syslog or Filebeat.
Key Components:
  • Adabas Auditing Server - Generates audit events from Adabas database activity
  • EntireX Broker - Messaging middleware that facilitates communication
  • Adabas Input Plugin (logstash-input-adabas_auditing_input) - Connects to the broker and retrieves audit messages
  • Adabas Filter Plugin (logstash-filter-adabas_guardium_filter) - Parses audit data into Guardium format
  • Guardium Universal Connector - Hosts the plugins and forwards data to Guardium
Architecture​
│ Adabas Database │
│ Audit Events
│ Adabas Auditing Server │
│ EntireX Protocol
│ EntireX Broker │
│ (Messaging Layer) │
│ Broker Messages
│ Guardium Universal Connector │
│ │ Input Plugin │ │
│ │ (adabas_auditing_input) │ │
│ │ - Connects to EntireX Broker │ │
│ │ - Retrieves audit messages │ │
│ │ - Parses binary format │ │
│ │ Filter Plugin │ │
│ │ (adabas_guardium_filter) │ │
│ │ - Transforms to Guardium format │ │
│ │ - Extracts metadata │ │
│ │ - Handles errors │ │
│ │ Output Plugin (Internal) │ │
│ │ - Sends to Guardium Sniffer │ │
│ Guardium Data Protection │
│ - Policy Enforcement │
│ - Reporting & Analytics │
│ - Alerting │
Prerequisites​
System Requirements​
Guardium System​
  • Guardium Data Protection Version: 12.0 or later
  • Deployment Type: Standalone system or Collector
  • User Permissions: S-TAP Management Application role
  • Network Access: Connectivity to Adabas Auditing Server's EntireX Broker
Adabas Environment​
  • Adabas Version: Compatible version with Auditing Server support
  • Adabas Auditing Server: Installed and configured
  • EntireX Broker: Running and accessible
  • Network Configuration: Firewall rules allowing Guardium to connect to broker port (default: 3000)
Software Requirements​
  • Pre-built plugin files (.gem files) provided by IBM or Software AG:
    • logstash-input-adabas_auditing_input-<version>-java.gem
    • logstash-filter-adabas_guardium_filter-<version>-java.gem
For Building Plugins from Source (Optional)​
  • Java Development Kit (JDK): Version 11 or later
  • Gradle: Version 6.x or later (included via wrapper)
  • Logstash: Version 7.5.2 or compatible
  • Git: For cloning repositories
  • Build Dependencies:
    • Guardium Universal Connector Commons library
    • Adabas SDK libraries (provided by Software AG)
    • EntireX libraries (provided by Software AG)
Required Information​
Before starting, gather the following information:
InformationDescriptionExample
Broker HostHostname or IP of EntireX Brokeradabas-broker.company.com
Broker PortPort number for broker connection3000
Broker ClassBroker class identifierADABAS-AUDIT
Broker ServerBroker server nameAUDIT-SERVER
Broker ServiceService name for audit dataAUDIT-SERVICE
UserAuthentication user for brokerguardium_user
TokenAuthentication token/password<secure_token>
Guardium Collector IPIP address of Guardium system10.0.1.100
Network Requirements​
Ensure the following network connectivity:
Guardium Collector → EntireX Broker
- Protocol: TCP
- Port: 3000 (default, may vary)
- Direction: Outbound from Guardium
Implementation Steps​
Step 1: Configure Adabas Auditing Server​
The Adabas Auditing Server must be properly configured to generate and publish audit events.
1.1 Enable Adabas Auditing​
Note: This step is typically performed by your Adabas administrator. Consult Software AG documentation for detailed Adabas configuration.
  1. Enable Auditing on Adabas Database:
    • Configure the Adabas database to generate audit records
    • Specify which operations to audit (reads, writes, DDL, etc.)
    • Set audit detail level
  2. Configure Adabas Auditing Server:
    • Install the Adabas Auditing Server component
    • Configure connection to the Adabas database
    • Set up audit event collection parameters
1.2 Configure EntireX Broker​
The EntireX Broker acts as the messaging middleware between Adabas and Guardium.
  1. Verify Broker is Running:
    # Check broker status (command may vary by platform)
    etbinfo -b <broker_id>
  2. Configure Broker Service:
    • Create or identify the service that will publish audit events
    • Note the broker class, server, and service names
    • Configure authentication if required
  3. Test Broker Connectivity:
    # Test connection from Guardium server
    telnet <broker_host> <broker_port>
1.3 Verify Audit Data Flow​
Before proceeding, verify that audit data is being generated:
  1. Perform some database operations on Adabas
  2. Check that audit events are being published to the broker
  3. Use EntireX tools to verify message flow
Step 2: Obtain or Build the Plugins​
You have two options: use pre-built plugins or build from source.
If IBM or Software AG has provided pre-built plugin files:
  1. Obtain the Plugin Files:
  2. Transfer to Guardium System:
    # Copy files to Guardium (from your local machine)
    scp logstash-input-adabas_auditing_input-*.gem guardium@<guardium_ip>:/tmp/
    scp logstash-filter-adabas_guardium_filter-*.gem guardium@<guardium_ip>:/tmp/
  3. Skip to Step 3 (Installation)
Option B: Building Plugins from Source​
If you need to build the plugins yourself:
2.1 Prepare Build Environment​
  1. Install Java 11:
    # Verify Java installation
    java -version
    # Should show Java 11 or later
  2. Download Logstash:
    # Download Logstash 7.5.2 or compatible version
    wget https://artifacts.elastic.co/downloads/logstash/logstash-7.5.2.tar.gz
    tar -xzf logstash-7.5.2.tar.gz
    export LOGSTASH_HOME=/path/to/logstash-7.5.2
  3. Obtain Required Files:
    • Download rubyUtils.gradle and versions.yml from Logstash GitHub
    • Copy to your Logstash installation directory
  4. Fix rubyUtils.gradle Issues:
    Edit rubyUtils.gradle and make these changes:
    Issue 1 - Fix JRuby Version:
    // Find this line (around line 20):
    classpath "org.jruby:jruby-core:${gradle.ext.versions.jruby.version}"
    // Replace with actual version from versions.yml:
    classpath "org.jruby:jruby-core:9.4.13.0"
    Issue 2 - Add YAML Parsing:
    // Add this code after the Ruby variables section:
    // Ruby variables
    def versionsPath = project.hasProperty("LOGSTASH_CORE_PATH") ? LOGSTASH_CORE_PATH + "/../versions.yml" : "${projectDir}/versions.yml"
    // Add YAML parsing code below:
    def versionsFile = new File(versionsPath)
    if (!versionsFile.exists()) {
    throw new GradleException("versions.yml file not found at: ${versionsPath}")
    def versionsData = [:]
    def currentSection = null
    versionsFile.eachLine { line ->
    def trimmed = line.trim()
    if (trimmed && !trimmed.startsWith('#')) {
    if (!trimmed.startsWith(' ') && trimmed.endsWith(':')) {
    currentSection = trimmed.replaceAll(':', '')
    versionsData[currentSection] = [:]
    } else if (trimmed.startsWith('version:') || trimmed.startsWith('sha256:')) {
    def parts = trimmed.split(':', 2)
    if (parts.length == 2 && currentSection) {
    versionsData[currentSection][parts[0].trim()] = parts[1].trim()
    gradle.ext.versions = versionsData
    versionMap = gradle.ext.versions
2.2 Build Guardium Commons Library​
  1. Clone the Commons Repository:
    git clone https://github.com/IBM/guardium-universalconnector-commons.git
    cd guardium-universalconnector-commons
  2. Build the Commons JARs:
    # Follow the README instructions to build
    ./gradlew build
    # Note the location of generated JAR files
2.3 Build Input Plugin​
  1. Clone or Navigate to Input Plugin:
    cd /path/to/universal-connectors/input-plugin/logstash-input-adabas
  2. Create gradle.properties:
    cat > gradle.properties << EOF
    LOGSTASH_CORE_PATH=/path/to/logstash-7.5.2/logstash-core
    EOF
  3. Build the Plugin:
    ./gradlew assemble gem
  4. Verify Build:
    # Check for generated .gem file
    ls -l logstash-input-adabas_auditing_input-*.gem
2.4 Build Filter Plugin​
  1. Navigate to Filter Plugin:
    cd /path/to/universal-connectors/filter-plugin/logstash-filter-adabas-guardium
    GUARDIUM_UNIVERSALCONNECTOR_COMMONS_PATH=/path/to/guardium-universalconnector-commons/build/libs
    EOF
  4. Verify Build:
    ls -l logstash-filter-adabas_guardium_filter-*.gem
2.5 Transfer Built Plugins to Guardium​
# Copy both .gem files to Guardium
Step 3: Install Plugins on Guardium​
Now install the plugins on your Guardium system.
3.1 Access Guardium CLI​
  1. SSH to Guardium:
    ssh guardium@<guardium_ip>
  2. Switch to CLI Mode:
    # If prompted, enter CLI mode
    cli
3.2 Install Input Plugin​
  1. Install the Input Plugin:
    grdapi install_universal_connector_plugin \
    plugin_file=/tmp/logstash-input-adabas_auditing_input-<version>-java.gem
  2. Verify Installation:
    # List installed plugins
    grdapi list_universal_connector_plugins
    Expected output should include:
3.3 Install Filter Plugin​
  1. Install the Filter Plugin:
    plugin_file=/tmp/logstash-filter-adabas_guardium_filter-<version>-java.gem
3.4 Clean Up​
# Remove temporary .gem files
rm /tmp/logstash-input-adabas_auditing_input-*.gem
rm /tmp/logstash-filter-adabas_guardium_filter-*.gem
Step 4: Configure Universal Connector​
Configure the Universal Connector to use the Adabas plugins.
4.1 Access Universal Connector Configuration​
  1. Log in to Guardium Web UI:
    • Open browser: https://<guardium_ip>:8443
    • Enter credentials
  2. Navigate to Universal Connector:
    • Go to: Setup → Tools and Views → Configure Universal Connector
4.2 Create Connector Configuration​
  1. Click "Add" to Create New Connector
  2. Enter Connector Name:
    • Name: Adabas_Production (or your preferred name)
    • Description: Adabas database auditing via EntireX Broker
  3. Configure Input Section:
    Click on the Input tab and enter:
    input {
    adabas_auditing_input {
    # EntireX Broker connection details
    host => "adabas-broker.company.com"
    port => 3000
    # Broker service identification
    brokerClass => "ADABAS-AUDIT"
    brokerServer => "AUDIT-SERVER"
    brokerService => "AUDIT-SERVICE"
    # Authentication
    user => "guardium_user"
    token => "your_secure_token"
    # Optional: Connection parameters
    retryInterval => 5
    retryCount => 10
    waitTime => 30
    receiveLength => 32767
    compression => 0
    # Optional: Metadata REST server URL
    # restURL => "http://metadata-server:8080"
    Parameter Descriptions:
    ParameterRequiredDescriptionDefault
    hostYesEntireX Broker hostname or IPlocalhost
    portYesEntireX Broker port3000
    brokerClassYesBroker class identifierclass
    brokerServerYesBroker server nameserver
    brokerServiceYesService name for audit dataservice
    userYesAuthentication usernameuser
    tokenYesAuthentication token/passwordtoken
    retryIntervalNoRetry interval in seconds5
    retryCountNoNumber of retry attempts10
    waitTimeNoWait time in seconds30
    receiveLengthNoMaximum message receive length32767
    compressionNoCompression level (0=none)0
    restURLNoMetadata REST server URL""
  4. Configure Filter Section:
    Click on the Filter tab and enter:
    filter {
    adabas_guardium_filter {
    # Source field containing audit data
    source => "adabas-auditing"
    Note: The source parameter should match the field name used by the input plugin (default: adabas-auditing).
  5. Review Configuration:
    • Verify all parameters are correct
    • Check for syntax errors (Guardium will validate)
  6. Save Configuration:
    • Click Save
    • Guardium will validate the configuration
    • If validation fails, review error messages and correct
For production environments, use Guardium's keystore for sensitive information:
  1. Create Secrets via CLI:
    # SSH to Guardium
    # Add broker credentials to keystore
    grdapi universal_connector_keystore_add \
    key=ADABAS_BROKER_USER \
    password=guardium_user
    key=ADABAS_BROKER_TOKEN \
    password=your_secure_token
  2. Verify Secrets:
    grdapi universal_connector_keystore_list
  3. Update Input Configuration to Use Secrets:
    input {
    port => 3000
    # Use environment variables from keystore
    user => "${ADABAS_BROKER_USER}"
    token => "${ADABAS_BROKER_TOKEN}"
    retryInterval => 5
    retryCount => 10
    waitTime => 30
  4. Save Updated Configuration
Step 5: Enable Universal Connector​
5.1 Enable via Web UI​
  1. In Configure Universal Connector Page:
    • Verify your connector configuration is listed
    • Click Enable button
  2. Wait for Startup:
    • Universal Connector will start (takes 1-2 minutes)
    • Status will change from "Disabled" to "Enabled"
5.2 Enable via CLI (Alternative)​
# SSH to Guardium
# Enable Universal Connector
grdapi run_universal_connector
5.3 Enable with Debug Logging (For Troubleshooting)​
# Enable with debug level logging
grdapi run_universal_connector debug_level=2
Debug Levels:
  • 0 - Errors only (default)
  • 1 - Warnings and errors
  • 2 - Info, warnings, and errors
  • 3 - Debug (verbose)
5.4 Verify Universal Connector Status​
  1. Check Status in Web UI:
    • The Enable button should change to Disable
    • Status indicator should be green
  2. Check Status via CLI:
    grdapi get_universal_connector_status
    Expected output:
    Status: Running
    Connectors: 1
Step 6: Verify Data Flow​
6.1 Generate Test Activity​
  1. Perform Operations on Adabas:
    • Connect to your Adabas database
    • Execute some queries (SELECT, INSERT, UPDATE)
    • Perform administrative operations if applicable
  2. Wait for Processing:
    • Allow 1-2 minutes for data to flow through the pipeline
6.2 Check S-TAP Status Page​
  1. Navigate to S-TAP Status:
    • Go to: Monitor → S-TAP Status
  2. Look for Adabas Connector:
    • S-TAP Host format: <adabas_host>:<broker_port>:UC<n>
    • S-TAP Version: Universal connector V<version>
    • Status should be Green (active)
  3. Verify Data Flow:
    • Check "Last Contact" timestamp (should be recent)
    • Check "Messages" count (should be increasing)
6.3 Check Guardium Logs​
  1. Access Universal Connector Logs:
    # SSH to Guardium
    # View recent log entries
    grdapi tail_universal_connector_log lines=100
  2. Look for Success Indicators:
    • Connection to broker established
    • Messages being received
    • No error messages
  3. Check for Errors:
    # Search for errors in logs
    grdapi tail_universal_connector_log lines=500 | grep -i error
6.4 Verify Data in Guardium Reports​
  1. Run Activity Report:
    • Go to: Reports → Activity → Activity Report
    • Set time range to last hour
    • Filter by database type: Adabas
  2. Check for Audit Records:
    • Verify records are appearing
    • Check that user names are populated
    • Verify SQL/commands are captured
    • Confirm timestamps are correct
  3. Review Session Details:
    • Go to: Monitor → Sessions
    • Look for Adabas sessions
    • Verify session information is complete
6.5 Test Policy Enforcement​
  1. Create Test Policy:
    • Go to: Policy → Policy Builder
    • Create a simple policy (e.g., alert on SELECT statements)
    • Apply to Adabas data source
  2. Trigger Policy:
    • Execute operations that match the policy
    • Wait for policy evaluation
  3. Check Alerts:
    • Go to: Monitor → Alerts
    • Verify alerts are generated for Adabas activity
Configuration Reference​
Complete Configuration Example​
Here's a complete, production-ready configuration:
# INPUT SECTION
input {
# Broker Connection
port => 3000
# Service Identification
# Authentication (using keystore)
# Connection Tuning
retryInterval => 5 # Retry every 5 seconds on failure
retryCount => 10 # Retry up to 10 times
waitTime => 30 # Wait 30 seconds for messages
receiveLength => 32767 # Maximum message size
compression => 0 # No compression
# Optional: Metadata Server
# FILTER SECTION
filter {
# Optional: Add custom fields
mutate {
add_field => {
"environment" => "production"
"data_center" => "DC1"
Environment Variables Reference​
When using the keystore, these environment variables are available:
Variable NamePurposeExample Value
ADABAS_BROKER_USERBroker authentication usernameguardium_user
ADABAS_BROKER_TOKENBroker authentication token<secure_token>
ADABAS_BROKER_HOSTBroker hostname (optional)adabas-broker.company.com
ADABAS_METADATA_URLMetadata REST server URL (optional)http://metadata:8080
Guardium Record Structure​
The filter plugin transforms Adabas audit data into this Guardium structure:
"sessionId": "mV20eHvvRha2ELTeqJxQJg==",
"dbName": "ADABAS-DB-001",
"appUserName": "APP_USER",
"time": {
"timestamp": 1705751051070,
"minOffsetFromGMT": -240,
"minDst": 0
"accessor": {
"dbUser": "NATUID_VALUE",
"serverType": "Adabas",
"serverHostName": "LPAR_NAME",
"sourceProgram": "NATPROG_NAME",
"language": "FREE_TEXT",
"dataType": "CONSTRUCT",
"dbProtocol": "Adabas native audit"
"data": {
"construct": {
"sentences": [
"verb": "READ",
"fields": ["FIELD1", "FIELD2", "FIELD3"]
"exception": {
"exceptionTypeId": "SQL_ERROR",
"description": "Response Code 3 (0) received.",
"sqlString": "READ with ISN 12345"
Troubleshooting​
Common Issues and Solutions​
Issue 1: Universal Connector Won't Start​
Symptoms:
  • Status remains "Disabled" after clicking Enable
  • Error in logs: "Failed to start Universal Connector"
Solutions:
  1. Check Plugin Installation:
    Verify both adabas_auditing_input and adabas_guardium_filter are listed.
  2. Check Configuration Syntax:
    • Review input and filter sections for typos
    • Ensure all required parameters are present
    • Verify quotes and brackets are balanced
  3. Check Logs for Details:
    grdapi tail_universal_connector_log lines=200
  4. Restart with Overwrite:
    grdapi run_universal_connector overwrite_old_instance="true"
Issue 2: Cannot Connect to EntireX Broker​
Symptoms:
  • Log message: "Failed to connect to broker"
  • Log message: "Connection refused"
  • No data flowing to Guardium
Solutions:
  1. Verify Network Connectivity:
    # From Guardium CLI
  2. Check Firewall Rules:
    • Ensure Guardium can reach broker port (default: 3000)
    • Check both outbound (Guardium) and inbound (broker) rules
  3. Verify Broker is Running:
    # On broker server
  4. Check Broker Configuration:
    • Verify broker class, server, and service names
    • Ensure service is registered and active
  5. Test with Broker Tools:
    • Use EntireX tools to verify broker accessibility
    • Test authentication credentials
Issue 3: Authentication Failures​
Symptoms:
  • Log message: "Authentication failed"
  • Log message: "Invalid credentials"
  • Connection established but no data received
Solutions:
  1. Verify Credentials:
    • Check username and token are correct
    • Ensure no extra spaces or special characters
  2. Check Keystore Values:
    Verify keys exist and are spelled correctly.
  3. Test Credentials Manually:
    • Use EntireX tools to test authentication
    • Verify user has permissions to access audit service
  4. Update Credentials:
    # Remove old key
    grdapi universal_connector_keystore_remove key=ADABAS_BROKER_TOKEN
    # Add new key
    password=new_token
    # Restart UC
Issue 4: No Audit Data Appearing​
Symptoms:
  • Universal Connector is running
  • Connection to broker successful
  • No records in Guardium reports
Solutions:
  1. Verify Audit Data is Being Generated:
    • Check Adabas Auditing Server is running
    • Perform database operations
    • Verify audit events are published to broker
  2. Check Filter Processing:
    # Enable debug logging
    grdapi run_universal_connector debug_level=3
    # Check logs for filter activity
    grdapi tail_universal_connector_log lines=500 | grep -i filter
  3. Look for Skipped Events:
    # Check for skip tags
    grdapi tail_universal_connector_log lines=500 | grep -i skip
  4. Verify Source Field:
    • Ensure filter source parameter matches input plugin output
    • Default is adabas-auditing
  5. Check for Parsing Errors:
    # Look for parsing errors
    grdapi tail_universal_connector_log lines=500 | grep -i "parse\|error"
Issue 5: Incomplete or Missing Data Fields​
Symptoms:
  • Records appear in Guardium but missing information
  • User names showing as empty
  • Database names not populated
Solutions:
  1. Check Adabas Audit Configuration:
    • Verify audit level captures required fields
    • Ensure user context is included in audit events
  2. Review Audit Event Structure:
    • Check that CLNT (client) data is present
    • Verify ACBX (control block) data is included
  3. Check Metadata Configuration:
    • If using metadata REST server, verify it's accessible
    • Check restURL parameter is correct
  4. Review Parser Logic:
    • Check filter plugin logs for warnings
    • Verify all expected fields are being extracted
Issue 6: Performance Issues​
Symptoms:
  • High CPU usage on Guardium
  • Slow report generation
  • Delayed data processing
Solutions:
  1. Adjust Connection Parameters:
    input {
    # Increase wait time to reduce polling frequency
    waitTime => 60
    # Increase receive length for batch processing
    receiveLength => 65535
  2. Enable Compression:
    input {
    compression => 1 # Enable compression
  3. Filter Audit Events at Source:
    • Configure Adabas to audit only necessary operations
    • Reduce audit detail level if appropriate
  4. Check Guardium Resources:
    • Monitor CPU and memory usage
    • Consider adding more collectors for load balancing
Issue 7: Universal Connector Stops After Reboot​
Symptoms:
  • Universal Connector not running after Guardium restart
  • Must manually enable after reboot
Solution:
After each Guardium reboot, restart the Universal Connector:
# SSH to Guardium
# Start Universal Connector
Note: This is expected behavior. Universal Connector must be manually started after system reboots.
Diagnostic Commands​
Check Universal Connector Status​
View Recent Logs​
# Last 100 lines
# Last 500 lines with timestamps
List Installed Plugins​
List Connector Configurations​
# Via Web UI: Setup → Tools and Views → Configure Universal Connector
Check Keystore Contents​
Restart Universal Connector​
# Normal restart
# Force restart (overwrite existing instance)
# Restart with debug logging
Stop Universal Connector​
grdapi stop_universal_connector
Log File Locations​
When creating a MustGather, these log files are included:
  • Universal Connector Log: uc-logstash.log
  • Logstash Standard Output: logstash_stdout_stderr.log
  • Guardium System Logs: Various system logs
Getting Help​
If you continue to experience issues:
  1. Create a MustGather:
    • Go to: Setup → Tools and Views → MustGather
    • Select all relevant options
    • Include Universal Connector logs
  2. Contact IBM Support:
    • Provide MustGather output
    • Include configuration details (sanitize sensitive data)
    • Describe the issue and steps to reproduce
  3. Check Documentation:
Appendix​
A. Glossary​
TermDefinition
AdabasA high-performance database management system by Software AG
Adabas Auditing ServerComponent that captures and publishes Adabas audit events
EntireX BrokerMessaging middleware for communication between Adabas and Guardium
Universal ConnectorGuardium framework for ingesting data from various sources
Input PluginComponent that receives data from external sources
Filter PluginComponent that parses and transforms data
S-TAPSoftware Tap - traditional Guardium monitoring agent
Guardium RecordStandardized data structure for audit events in Guardium
ACBXAdabas Control Block Extended - contains command details
CLNTClient information block in Adabas audit data
B. Port Reference​
PortProtocolPurposeDirection
3000TCPEntireX Broker (default)Guardium → Broker
8443HTTPSGuardium Web UIAdmin → Guardium
22SSHGuardium CLI accessAdmin → Guardium
C. File Locations​
File/DirectoryPurpose
/tmp/Temporary location for plugin .gem files
Guardium internalUniversal Connector logs (accessed via grdapi)
Guardium internalPlugin installation directory (managed by Guardium)
E. Quick Reference Card​
Essential Commands​
# Check status
# View logs
# List plugins
# Stop Universal Connector
# Restart with overwrite
Configuration Template​
input {
host => "BROKER_HOST"
port => BROKER_PORT
brokerClass => "BROKER_CLASS"
brokerServer => "BROKER_SERVER"
brokerService => "BROKER_SERVICE"
filter {
F. Version History​
VersionDateChanges
1.02025-01Initial implementation guide
Support and Feedback​
For questions, issues, or feedback regarding this implementation guide:
  • IBM Support: Contact your IBM support representative
  • GitHub Issues: Universal Connectors Issues
  • Documentation Updates: Submit pull requests to improve this guide
Document Information:
  • Title: Adabas Universal Connector Implementation Guide
  • Audience: Guardium administrators, Database administrators
  • Prerequisites: Basic knowledge of Guardium, Adabas, and networking
  • Estimated Implementation Time: 2-4 hours (excluding Adabas configuration)
This guide is provided as-is and may be updated as new versions of Guardium or the Adabas plugins are released. Always refer to the latest official IBM and Software AG documentation for the most current information.
